US Roaming - Talk Text (10-day)
mschmutz
Is the US Roaming - Talk Text (10-day) plan still a good option for traveling to the US. Will we connect to their 4G towers or only the 3G towers that are now decommissioned?
I also have a sim card with Koodo but their Easy Roam plans are $12 a day
Yummy
I would not rely on this add-on as many report issues in different parts of USA.
hairbag1
Which area of US are you going to ?
My only recent experience is using the add-on whilst traveling in Washington state.
JL9
Lots of nightmare stories about the PM roaming and lots of ppl clamouring on here after their trip about their horrible experience and demanding a refund - so caveat emptor and then some
Dunkman
If you need reliable service, I would go with Koodo.
Public mobile data should be working fine, since it will use LTE network. However, talk will rely on the T mobile 2G network, which is unreliable depending on where you are visiting and the particular area.
dust2dust
You would need to manually connect to T-Mobile. Talk is the primary problem. Text and data should theoretically work fine. And then last night someone posted some interesting comments that maybe we can use Verizon. I highly doubt it but they seemed to be saying that an agent told them that.
