01-11-2020 11:29 AM - edited 01-05-2022 10:18 AM
Hi there,
With the US roaming bundle for $20 for 10 days...what can I do when I am in the states? Can I make a call to a US number while I am in the US with no long distance charges. Can I make calls to Canada while in the US with no long distance charges? Can I use data on the road with my GPS on phone?
Thanks in advance
01-11-2020 03:35 PM
@Lisasusanhill You should know that after you return and after the roming add-on expires, your incoming text messaging will stop working for 24 hours. This is a long-time bug that Public Mobile has not yet been able to fix.
01-11-2020 12:41 PM
Be sure to buy the add on the day you arrive in US to use the full 10 days of service. Buy early in the day.
01-11-2020 12:25 PM
@Lisasusanhill wrote:Hi there,
Thanks in advance
@LisasusanhillAs many people answered, yes, you can do everything you have listed. Have fun in US![]()
01-11-2020 11:32 AM
@Lisasusanhill yes you can do all that, it's unlimited calling but the Data isn't unlimited! The day you purchase the add on is day 1 of 10 so don't buy it a few days before. Also to purchase it don't forget to add the available funds to the account and then go in purchase add ons and purchase it
01-11-2020 11:30 AM - edited 01-11-2020 11:32 AM
Thanks in advance
Yes you can call both USA and Canada
And you have 250 MB of data to use.
To buy the add-on, add money to your account, then go to purchase the add-on.
It is active immediately upon purchase and will expire after 10 days.
01-11-2020 11:30 AM
Thanks in advance
Yes to all.
