US Long distance add-on
thedmcking
Is there any expiry for long distance add-ons?
Triguy
They remain in your account until they have been used up
hairbag1
No expiry date...only when you use up the 1000 minutes does it expire...even if that takes several months or longer.
Jb456
No sir Mr King. Rolls over until all used up. Can keep it for years 🙂
You can consider just downloading the textnow app. You get a Canadian number in your area and make calls text to Canada and a USA numbers for free on wifi or data.
