07-17-2022 12:54 PM - last edited on 07-24-2022 11:01 AM by Dunkman
Landed in Seattle yesterday,
I paid for the US data top up and it is not working. My wife and I have the same plan and paid for the same top up. Hers is working. Mine is not. Why?
09-18-2022 12:47 PM
07-17-2022 02:03 PM
I apologize to all. In error I was in my wifes account and not mine when I advised I had purchased the US data. /you are very correct. In error I bought extra canada data. Just purchaed us and problem solved.
07-17-2022 01:43 PM
I only see the option of 3G or LTE
07-17-2022 01:36 PM
Sorry I looked back and it was 15.oo for us roaming talk and text (10 day) and us raoming 1GB Data $20
07-17-2022 01:36 PM - last edited on 07-27-2022 11:48 AM by Luddite
I suspect you got the talk/text bundle and 500MB of data. That would total $30. But what are you showing for your balance?
What make and model is the phone? If you can dig down in your connection settings where it might say LTE or 3G, maybe you can find mention of 2G in there. It's just to test and verify that 2G works. The phone should do this automatically. And then again, 2G isn't everywhere either so it just might not be available where you are.
Can you look in your payment history for the transactions of all this. You should see the payment and then the items you bought.
[wrong data add on purchased .......... Luddite]
07-17-2022 01:29 PM
purchased prior to leaving canada on self serve using credit card and was issued a receipt
07-17-2022 01:28 PM
not able to browse a website or send texts
07-17-2022 01:21 PM
10 day roaming
07-17-2022 01:16 PM
How do I change to 2 G?
07-17-2022 01:16 PM
@BigO The issue with your wife unable to talk is the shutdown of 3g in the states, what your saying you paid doesn’t seem to add up , I have to ask did you get 10 day roaming or regular talk to U S ?
07-17-2022 01:12 PM
When did you purchase the add-ons? There was a whole system change on the 13th. What do you show in your balance now?
The calling is the tricky part these days. Supposedly via T-Mobile we can use their old 2G for talk. But the phone has to be able to do that. Normally it should automatically switch down from LTE but you could also try setting the phone to 2G only.
07-17-2022 01:11 PM
Roaming is on
Yes Data is on
Account is active
Network selection shows T-mobile
Yes. Purchased both
Talk and text and addition data
07-17-2022 01:08 PM
Purchased and paid for add ons before I left Canada. My wife's data is working, she is able to text, but cannot call.
07-17-2022 01:08 PM
And those add-ons are showing on the right with those circles of usage?
Does anything work? Can you browse to a website? Send and receive texts? Talk might be an issue.
07-17-2022 01:06 PM
Correction. It did show t-mobile in settings under cellular
07-17-2022 01:02 PM
Roaming is on. show t-mobile. Paid for talk and text and a data top us $30 total
07-17-2022 01:01 PM - edited 07-17-2022 01:02 PM
@BigO Hi did you do the two steps to purchase?1st put money in your account then go in and purchase your add on
07-17-2022 12:59 PM
Did you turn on data roaming? Did you turn on data? Is your account active? Are you connected to either AT&T or T-Mobile? Did you also get talk and/or text?
