02-26-2024 05:33 PM
Hello! I just purchased the US Canada Plan so that I can use my phone in the States. I am wondering what I need to do to my phone when I arrive in the US? Do I have the data roaming on or off? Do I need a different SIM card? Just wondering how to use it seamlessly so that I don't get charged extra. Thanks in advance!
Plans
02-26-2024 06:34 PM
Awesome! Thank you!
02-26-2024 06:00 PM
HI @Schmidtty
you don't have to worry, iPhone 12 will work VoLTE and voice would work
02-26-2024 05:57 PM
I have an Iphone 12
02-26-2024 05:56 PM
Thank you, that is also very helpful!
02-26-2024 05:51 PM
HI @Schmidtty
yes data roaming needed to be turned on because you are using a different network, an US network
generally, make sure you are able to connect to AT&T or T-Mobile network. If the phone cannot do it for you, try to manually connect to it
and, disable 5G, use 4G, it is much easier to use 4G network
For voice, depends on your phone, it might be more steps. But what phone are you using?
02-26-2024 05:47 PM
FYI...you can just leave data on all the time. No worrys of overages 'cause there are no overages here. All plans and add-ons are pre-paid so unless you pay ahead of time...it won't work. Once you reach your plan data limit..it'll just stop until next renewal...you won't be billed for anything extra later on.
02-26-2024 05:41 PM
Okay, thank you very much for your help.
02-26-2024 05:35 PM
@Schmidtty Yes have dat roaming turned on in phone settings . And put phone to 4G/LTE not 5G and connect to T mobile or AT&T and enjoy your trip 🙂
