US-Can Plans
Canlab
The USA-Can plan for $60/month are you able to call from USA to Can?
Teagan30
Yes! You can ◡̈
Hi @Canlab
yes, you can.  You can call US and Canada from US , and you can use your data like you are in Canada
@Canlab  Yes and vise versa from CAN to  the U.S. it’s a true snow bird plan use it here and in the U.S. like you were at home for talk text and data . Just be sure to turn data roaming on in phone settings when in the U.S.
hairbag1
@Canlab
yup. Just make sure you have a volte enabled cell for best talk experience.
