10-10-2023 03:07 PM
I need to make a US call. When I try to make the call I get a message saying that I'm out of minutes. I bought 15 days of US talk/text add-on. It's showing up in my account. However, I've restarted my phone and I still get the same error message. How long does it take for add-ons to take effect?
10-10-2023 03:10 PM - edited 10-10-2023 03:13 PM
If you are calling while in the USA, you will need to manually change the cellular network setting to T-Mobile or AT&T.
If you are calling while in Canada, you need to purchase a LD USA calling add-on.
But you can use WhatsApp or TextNow app on WiFi for free calling and texting.
10-10-2023 03:09 PM
you got the wrong addon if you are calling from Canada. the 15 days is for use when you are in US
you should get this one:
1000 U.S. Long Distance Minutes - $15.00 (10 Rewards points) all 50 states, plus Pureto Rico and the US Virgin Islands
Message support and they can change it for ou
