03-29-2024 05:41 PM
Paid for $30 data / text add on and it’s not working today
Add-Ons
03-29-2024 08:52 PM
Did you try resetting your Network Settings then rebooting?
03-29-2024 08:23 PM
T mobile on all day
couldn’t get 2g - only 3 or 4 - still nothing
re started phone like 5 times
03-29-2024 08:22 PM
I’m on a 13 pro max
never had an issue before today and I go to the US frequently 🤷🏻♀️
03-29-2024 08:20 PM
Thanks - tried this still no bueno. Hasn’t worked all day so no cat videos for me sadly
03-29-2024 06:02 PM
Hey @Fiona66
I'm in the states often and this is what I do to resolve it.
I go into my network settings, I turn OFF automatic and then pick T-Mobile. Then I make sure my data roaming is also turned on them I reboot. From there, I'm up and running and watching horrible cat videos. Ugh.
03-29-2024 06:01 PM
if you paid $30 for the 15 Day US Roaming add-on, you get talk / text and 3GB's data. Make sure Roaming Data is enabled in Settings on the phone. You should have no trouble with send / rec texts. Your phone needs to be on PM's whitelist for VOLTE to best talk-ability. Let us know which phone you have and we can look to see if it is on the list. Otherwise, you need a cellphone that can drop to 2G for calls as the US has shut down their 3G. VOLTE works on LTE so hopefully you have a newer phone.
03-29-2024 05:55 PM
If possible, put your phone to 4G/LTE and connect to T-Mobile or AT&T.
If calls still don't work, put your phone to 2G and connect to T-Mobile. From the settings menu, turn on data roaming.
Might have to restart phone.
I hope this will be helpful.
