01-11-2024 05:16 PM
I have recently switched to public mobile and transfered my number over from chatr. I have since not been able to recieve verifiation texts or calls from my bank. I was told to wait 3-5 days after transfering the number, I have since waited about 12 days and still no difference. I have also started to notice that I'm not recieving calls from certain people. This has led to problems with my bank as they will not send these codes via email. Is there a solution?
01-11-2024 06:27 PM
Hey @PhilipB
I've heard it can take a couple of weeks for that feature to kick in. If it has been 12 days of service, you can always ask a CS Agent to reset your network on their end to maybe resolve this. Or they may ask you to wait a few more days. This is standard practice.
01-11-2024 05:30 PM
I got rid of my chatr sim about a month ago when I switched. I will do what you suggested, hopefully it helps. Thank you
01-11-2024 05:24 PM
Is your chatter sim still work?
I would message cs at the link below.
I would also contact the port and team to inquire. I send you another message with the number.
