02-02-2020 12:00 PM - edited 01-05-2022 09:18 AM
I purchased two roaming add ons by mistake. How do I delete one of them?
02-02-2020 12:54 PM
@PAULRANG18 wrote:Moderators have to remove roaming add ons. No other way. Only one can be active at a time. Contact moderators by clicking ?, bottom right, and follow instructions to submit a ticket.
@PAULRANG18 this is incorrect. You can have multiple different USA addons, active at the same time. The only issue I know about is if you have 2 addons that both have voice options .
02-02-2020 12:20 PM
02-02-2020 12:16 PM
@John133 which addons did you buy? Are they both showing up in addons is it possible one is sitting in available funds?
Just to clarify @gblackma reply@ you can not purchase the same add-on on same 10 day period. Ie you can't buy the 1gb data twice, but you can buy the 1 GB and 500mb data addons and they will work.
The issue of add-on not working is when you have two addons that include voice calling. They interfear with each other causing voice calling not to work properly.
02-02-2020 12:05 PM
02-02-2020 12:01 PM - edited 02-02-2020 12:02 PM
@John133 wrote:I purchased two roaming add ons by mistake. How do I delete one of them?
@John133 Only moderators can help I believe. To contact them, click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
