U.S. Roaming Add-on
SBenz
Hi
I've purchased a 1GB US Roaming Add on about 5 days ago and I'm already out of data. I would like to purchase another one but apparently I need to wait for the first one to expire? This seems wrong. could you please advise me how to purchase another 1GB (and not 2 500mb which is much more expensive)
thank you!
Hi @SBenz   If you used up 1GB in 5 days, how long more you will be in US?  Why not get local prepaid data?  It is easier, cheaper and you get more data that way
Meow
Talk to agent to override 10 days limit and purchase US add-on for you. Have money on account first.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
MrSpock
@SBenz open a ticket through Simon to speak to a customer service agent they can help you  Click here
JL9
Yeah only option is connecting with a CSA, they can manually do it for you so it is running immediately
dust2dust
The only option in your desired scenario is to deposit money and then ask the support people to re-buy it for you.
And you wouldn't be able to buy 2 500's for the same reason. You could choose to buy one and see if that holds you until the other expires in 5 days (+1).
