12-17-2019 04:08 PM - edited 01-05-2022 08:35 AM
Is there a way to add additional cellphone plans under one account?
Joining Public
12-27-2019 04:46 PM
And each account needs a unique e-mail address for it's username.
One trick if you use Gmail, is you can just use the + alias feature... Anything after a + sign in the user portion is ignored - so for example: example+pm2@gmail.com delivers to example@gmail.com automatically... And then the mail for both public mobile accounts goes to the one gmail box.
12-17-2019 09:38 PM
@goauldgungan wrote:Is there a way to add additional cellphone plans under one account?
I don't think so. When you register an acount, they ask you for the phone number and contacting email. So my understanding is each account only associates with one phone number. You need to register 2 separate accounts if you have 2 phone numbers.
Please make sure your self-serve account is also different from your community account.
12-17-2019 04:44 PM
Only one plan per account allowed.
12-17-2019 04:18 PM
Only one plan per account...
12-17-2019 04:10 PM
@goauldgungan No, one sim per account.
