Two e-SIMs.
Priority
Does anyone have any experience using and installing a second Public Mobile e-SIM on a phone which already has one existing already from another account?
Say if I make a new Account with a new Phone Number, can I add it as a secondary e-SIM without it removing the first Public and default one?
8 REPLIES 8
Priority
Yes, the 'Welcome to Public Mobile' email is still being sent out to all new Activations.
I've provided screenshots on the post you tagged me in fir reference. 🙂
Well you're doing all these activations so you have a large base of practice to work with. Did you see my other tag for you? I asked about whether a welcome email is still being sent out. Are they?
Priority
I just decided to give it a go since I am the known Guinea Pig around here, and it just added the new one into SIM Manager. It left the one from my other Public Account alone.
Success!
@Priority wrote:
I'd say the soonest we are going to see e-SIM for existing Accounts is in September when the SIMless iPhone 15 is released to Canada.
It will force Public to make that available to everyone.
@Priority
next guess, but eSIM for existing should be around the corner, sooner than Sept  🙂
Priority
@Priority wrote:
Maybe I'll just use a Physical SIM, safer bet anyway.
@Priority
at the moment YES
but likely you can change it back to eSIM for existing accounts or PM can regenerate new QR code really soon.  hoping another month or two
Priority
@Priority
should work, it is more a device issue and not a network issue
make sure you are not deleting  PM eSIM, at this point, PM still cannot provide replacement eSIM
