06-29-2021 08:43 AM - edited 01-06-2022 02:38 AM
I had some issues porting my number to Public Mobile from Telus and I accidentally created two accounts for one phone number. How do I close the second account as I don’t even know the account number? But I was charged twice.
06-29-2021 12:34 PM
I am surprised that you created 2 accounts with 1 PM SIM number.
Anyway, as commented by others. You need to contact a moderator by clicking on the SIMon chat button and create a ticket for the moderator to help you.
06-29-2021 09:15 AM
You might have just been charged twice instead of getting two accounts. PM has noticed a glitch in the PM activation portal system. New customers may be charged on their credit card if they encounter an error in the activation process. If customer makes an error in the porting information (ie. missing details), the activation fails, but the credit card is still charged.
As mentioned above, you should contact moderator to check your account(s) and likely issue a refund within 3-5 business days.
06-29-2021 08:49 AM - edited 06-29-2021 08:50 AM
@PKC23 There should be just one phone number (one SIM card) one account on https://selfserve.publicmobile.ca and username is the email address
Try logging in account with the 2 accounts you believe you created and see if you really can logon with both. After you logon go to Plan and Add-Ons tab and check what Phone number it is showing there. If you really created 2 accounts, you should see different numbers there
As to account number, it is on the Overview Tab..
06-29-2021 08:46 AM
You should contact a moderator.
Here’s when and how to contact the Moderator Team:
