05-08-2021 12:45 PM - edited 01-06-2022 02:00 AM
05-08-2021 02:15 PM
@HALIMACS my dear friend i try it now at Microsoft Edge
05-08-2021 02:01 PM
I'm using Chrome from a mobile device and am experiencing the same result as you - there are no plans to select on the change plan tab.
Recommend trying once an hour, as it is not unusual for public mobile to be doing site maintenance on the weekends (which can be hit-or-miss) when trying to do these types of self serve functions.
05-08-2021 12:56 PM
Clear your browser. Reboot your device. Open one tab only in secret/incognito mode using chrome, firefox or safari. Log in and try again. Unless your son needs more data now schedule a plan change on next renewal. Or consider the $15/1gb add on if just a little data is needed to supplement the $15 plan....as it rolls over each 30 days until completely consumed.
Moderator contact is not needed.
05-08-2021 12:49 PM
I just tried, mine is fine.
try wait 10 mins and logon again. If possible, try with another browser. Or try with Incognito mode
05-08-2021 12:49 PM
@seansolo : Give it a little while. Maybe try a different browser or clear cache/site cookies or use incognito/privacy mode. It happens frequently.
05-08-2021 12:47 PM - edited 05-08-2021 12:53 PM
try to use a different browser,
and clear your browser's cache and cookies
if still not open it you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
Good Luck
