07-30-2018 01:10 PM - edited 01-05-2022 05:13 AM
Hi there,
I ended up signing 2 new accounts with PM yesterday at Walmart (Free Sim Cards and 2nd month free). Popped in the 2 new sim cards and it worked without any issues (although I had to manual input the APN settings to enable data). I would like to try PM service for a few months before I eventually port over. Question is....will I be able to port in my 2 #'s from Rogers to replace the 2 existing PM #'s if I decide to stay with PM?
Thanks in advance for your help!
07-30-2018 03:59 PM
to piggyback on this MAKE SURE the rogers accounts are still active so you can port them!! if you cancel and then try and port they are gonnnnnnneeee 😞
07-30-2018 01:18 PM
Yes. You can port your Rogers number to PM anytime using online change number.
07-30-2018 01:17 PM
Yes, as long as your Rogers' numbers are active, you just need to log into self serve and click on the Plans and Add-ons tab and then Change Phone Number.
