Trouble shooting
Hermela2006
I have a problem whenever someone calls me I don’t receive their call. But when I call they get my calls. What can I do in this situation?
2 REPLIES 2
slusagm
this used to be a common issue with some handset
What phone do you have?  Try to set your network mode to 3G and test couple days and see if the issue is gone.
@Hermela2006  Did you just port your number to public mobile ? And did you leave old providers SIM card in the phone to reply YES to the confirmation text ? You would have had to reply YES to it with in 90 mins if receiving the text if you didn’t reply to text you will need supports help to fix
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
