49m ago
I downloaded the app and I see the esim option appearing under my phone settings but I'm still not able to access data or texting or phone. My data setting says the public esim is not connected. I also transferred my number and it's unclear if it's complete. I know my number is no longer registered with my former provider. Please help. I have a Google pixel 7
42m ago
hi @adamjfries use this link to message support agent:
43m ago
you removed or disable old sim card/esim?
PM sim is enabled and set as Primary? Reboot phone and reset network settings
if you still unable to make it works, ask PM to check if the activation was done properly on the back end
Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://widget.telus.tiia.ai/libs/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&lang=en&toggle=fal...
(For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
43m ago
Also I get this message:
47m ago
in cellphone settings, disable the esim from old network and set the Public Mobile esim as primary.
48m ago
hi @adamjfries
Make sure you removed the old carrier sim card, or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Then put the PM sim card in the phone, or if eSIM, you should be good
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help. You can actually open ticket right at My Account (or PM app) using the new Expert Messaging that just introduced today. Submit ticket with Customer Support through Expert Messaging in one of these ways:
If you cannot access My Account/PM app, use this link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
please use the same Community account login you are using now to login and submit ticket
