Trouble Transferring Number
1NQU1S1T10N
I recently switched to mobile here, everything was going fine until I didn't receive my 90min transfer verification from Rogers.
I called Rogers and am told I need Public to Send the transfer request again so I can approve it or call them so they can approve manually approve it.
I've also tried to open a few support tickets but get errors opening them.
1NQU1S1T10N
Fantastic thanks!
TheSterlinger
I will send you the porting department’s number.  Check your inbox, click your avatar and click messages.
@1NQU1S1T10N  No worries I’ll send you the porting team number private message right away . And they can re trigger the port request for you
