07-07-2022
02:59 PM
07-07-2022
03:59 PM
computergeek541
Hi there, My name is Cole and I'm still waiting on my SIM card, it's been a few weeks. Can I get an update on the shipment status if possible?
Thanks,
Cole
07-07-2022 05:37 PM
Unfortunately it seems to be 3 weeks and actually longer. The delays seem to keep increasing. People jump on here and usually find out too late after ordering it. I would recommend either going in store or ordering from a place like Canadian Cell Supplies, not only is it like 70% cheaper there, you actually get it really quick. You can connect with a CSA and ask for a credit to the account due to the long wait and you going elsewhere but no guarantees. Even so you can use it as a back up sim for yourself or give it to a friend/family member in order to get the referral bonus.
07-07-2022 03:12 PM
HI @colechal2 It could be as long as 3 weeks for PM to ship sim card
Best to open a ticket with PM and see if they can find out if they already shipped out yet.
send a private message to the moderators
07-07-2022 03:08 PM
@colechal2 Hi you could try customer service for an update
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
07-07-2022 03:03 PM
@colechal2 Hi it can take up to three weeks they are slow hopefully it will be there soon
