03-20-2019 07:58 PM - edited 01-05-2022 03:50 AM
I tried to get into my account. I got in, but got a strange screen instead: nothing on screen except "hello". Did the account get hacked?
My Account
04-07-2019 03:27 PM
Hello, thanks for your response. Yours was the one that worked: I msg'ed the moderator. One day before my payment date, the account was fine. I could get in. I don't know why. Maybe the mod tweaked the account.
I used www.publicmobile.ca. Thanks.
03-20-2019 10:18 PM - edited 03-20-2019 10:19 PM
@robiniom wrote:Hi lynn89 ,
The account is not hacked and nothing wrong with it .
The strange screen which u got maybe from your phone which you should just to restart it and if you get the same screen plz make sure u are using the wright websit , www.publicmobile.com.
Thanks
The correct website for Public Mobile is publicmobile.ca
As said earlier, based on the information provided so, far there is no way to know that the OP is going to wrong website by mistake.
03-20-2019 09:10 PM
Thanks
You're drawing conclusion without even asking for screenshot or anything, not minding the typos and the wrong domain. Not okay.
03-20-2019 09:08 PM - edited 03-20-2019 09:13 PM
Thanks
No. publicmobile.ca
Edit: @Lynn89 somebody just this past Monday had the same thing that is so far unresolved.
03-20-2019 09:00 PM
Hi lynn89 ,
Thanks
03-20-2019 08:29 PM - edited 03-20-2019 08:30 PM
@Lynn89 wrote:I tried to get into my account. I got in, but got a strange screen instead: nothing on screen except "hello". Did the account get hacked?
Try a browser WITHOUT any extensions, or even on another WiFi.
If such situation repeats, go straight to Ask a moderator (Can take up to 48 hrs, 1 message at a time) because this seems to be very concerning.
03-20-2019 08:08 PM
I just tried and was able to login. Took a bit of time to login in though. Unlikely a hack, but possible, I guess.
The website is finicky. You could try a different web browser. Chrome and Firefox latest version seems to work the best. Maybe incognito mode might be helpful, or clearing cache.
