Tried to change my plan..
02-01-2019 06:07 PM - edited 01-05-2022 03:13 AM
02-01-2019 06:23 PM
@Bobbi224 wrote:I usually go with the $45 plan but noticed the $50 one so I tried to go with that one instead.. added $48 to my account and went ahead to change it... says that my balance is $5? ... so I'm assuming it automatically added the $45 plan.. is there any way in changing it?
The find out which plan you have. Login to your self-serve account. It will be shown on the overview page after self-serve login.
When is your renewal date?
If you did the change plan immediately, you will not get any refund of the unused portion of your current cycle because PM plan is prepaid plan and there is no refund for prepaid plan in Canada.
02-01-2019 06:14 PM - edited 02-01-2019 06:15 PM
@Bobbi224For plan change corrections, you need to contact the mods. The moderator team can be reached via private message using this link.
02-01-2019 06:11 PM - edited 02-01-2019 06:13 PM
If you added funds on or after your renewal date it would automatically go towards renewing your current plan. Your best option now would be to select to change your plan to the $50 one on your next renewal date, if you choose to change it immediately then you will lose the rest of the plan you just paid for and have to pay for the new one.
02-01-2019 06:11 PM - edited 02-01-2019 06:15 PM
@Bobbi224 when is your renew date?? If you wanted to change the same date as your renew...the system can be mixed up...You will need to clik for a change plan for your next RENEWAL date. Can you see it in your account??
