04-08-2019 04:23 PM - edited 01-05-2022 04:14 AM
If i travel to another country will my phone still work with public mobile?
04-08-2019 05:50 PM
(moved from Rewards to Plans & Add-ons)
04-08-2019 04:36 PM
If international, you'd need another prepaid SIM and you'd need to ensure that it works on the country/location you're travelling on. You could try to use Fongo calling and/or Text me for calls and texts over wifi but you'd need to have steady access to a wifi signal. What type of phone and what country?
04-08-2019 04:33 PM
@phustler7 wrote:If i travel to another country will my phone still work with public mobile?
Public Mobile is strictly a prepaid service and will only work in Canada. If you are traveling to a country other than the US it will not work. For it to work in the US you need to purchase a seperate US-Roaming addon.
If you keep your account active when you come back it will work. If your away for more that 90 days and to don't make any payments your account will be de-activated and you will need to signup again with a new SIM.
04-08-2019 04:24 PM - edited 04-08-2019 04:25 PM
No. The only country it will work in is the USA with a roaming package.
Edit this link might have some tips.
