4 hours ago
Going on a business trip to Europe for a week. Does PM have an add on plan that works for data, text, & call in Europe or do i need to buy a travel SIM ?
4 hours ago
@JAW2, unfortunately PM does not offer roaming with the exception of the U.S. You will need to either get a local plan to the region you will be staying or you can look into Airalo or if you can get by with just WiFi and apps like WhatsApp or Messenger. You can even look into using Textnow but you will need to get a different number
4 hours ago
@JAW2 No sorry PM only has roaming in the USA . You would need travel sim as you suggested or local pre paid SIM card
