03-12-2022 08:34 PM - last edited on 03-12-2022 10:05 PM by computergeek541
I will be traveling soon overseas , and the country I will be arriving require me to download an app that I must present my information when arriving at airport. Is Is possible to turn on phone and the app as well when I arrive?
03-13-2022 12:04 AM
Thankyou for the thorough information. I will try one of the ideas.
03-12-2022 11:59 PM
Thankyou for your help.
03-12-2022 11:58 PM
I didn't think of that. Thankyou, I will try that. Appreciate your help.
03-12-2022 11:55 PM
You are right. Thankyou for your help.
03-12-2022 11:55 PM
Thanks
03-12-2022 11:54 PM
India. I appreciate your help. Thankyou
03-12-2022 11:53 PM
India
03-12-2022 11:37 PM
03-12-2022 09:45 PM
Download the app and have everything set up before you leave Canada. Also consider downloading a voip app such as fongo or textnow. If you wish you can call forward you pm number while still in Canada to your voip number if you want to get your incoming pm calls to ring thru on your voip number. You can change to the $15 plan to keep your costs low.
Once at the airport of your destination use the free wifi to access the required app. Once thru customs there will be options to purchase a local sim card or you can wait til you arrive near your accommodations to purchase a sim card and plan. This blog may help you with local sim cards...
https://toomanyadapters.com/buying-local-sim-cards/
Here are some options for your pm service....
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels and Stay--Safe!
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
03-12-2022 09:27 PM - edited 03-12-2022 09:28 PM
Another option would be to:
When you are at the location where you need to display them, bring up the items in your photo library to show what is needed.
03-12-2022 09:07 PM
Keep in mind that apps, photos, videos, music, etc... Storage on your phone are nothing to do with your carrier. However some apps(almost all of them) require internet connection so you can connect your phone on wifi because mobile data will not work due PM only provides roaming on US.
03-12-2022 08:50 PM
Outside of Canada, PM does provide service in US (with add-on) only.
If app requires internet access to present proof of vaccination or similar, most if not all airports have free WiFi so you can use that to access Internet.
03-12-2022 08:50 PM
@Missmylan Most international airport has Wifi for free. I think you should be good with that?
Which country you are going ? PM only has US roaming and nowhere else.
However, many stores has local Data SIM available here in Canada. You can buy from them ahead or some even have it on Amazon. where you are going and I can try to search one for you.
03-12-2022 08:37 PM
@Missmylan , what country are you traveling to? Public Mobile only offers roaming in the US and you have to buy an add-on to have cellular service in the US.
