Traveling from Canada to US, I got signal the first few days but now there's no signal.
08-03-2022 12:39 PM
- No signals: it doesn't recognize AT&T nor Verizon, I tried to change to automatic but still no luck
- I removed the SIM, an insert it back, no luck.
- I tried the SIM in a different phone, no luck.
- I rebooted the phone (iphone), and I also restarted the network setting.
- My US Roaming plan is active, in fact it worked fine for few days. Just in case I bought another add-on, but still no luck.
Any ideas what else I could try? I'm in the NYC area.
Service
08-03-2022 01:20 PM
@jotasanta wrote:I actually just care about SMS, I don't even care about data anymore. What do you mean by "did you see t-mobile?" ? like I contacted them?
Do you see T-Mobile on your phone's available Network list?
Try to manually connect to T-Mobile if you do
If you just care sms, you can connect to either AT&T and T-Mobile. whichever you can connect, your SMS should work
08-03-2022 12:57 PM - edited 08-03-2022 12:58 PM
@jotasanta T Mobile should show up when you try to connect manually , Public is in partnership along with ATand T if you were going to be there any amount of time I would suggest getting a local sim
08-03-2022 12:50 PM
08-03-2022 12:48 PM
I got these add-ons:
08-03-2022 12:44 PM
@jotasanta hi did you see t mobile ? they are shutting down the 3 g network if you done all that contact a cs agent for help or a refund
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
08-03-2022 12:41 PM - edited 08-03-2022 12:44 PM
@jotasanta I would try to use manual network selection
The two you want to try is AT&T and T-Mobile (PM does not partner or Verizon)
Without AT&T signal, try to manually connect to T-Mobile
Also, what kind of roaming add-on you got?
