01-11-2024
02:02 PM
01-12-2024
12:27 PM
Dunkman
I am a new subscriber. After the process my phone can phone out but can cannot receive call with the transfered no.
Is-it because it is still using a temporally no during the process. I don't know the temporally no. or where to find it
01-11-2024 02:17 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
