Transferring phone number
09-24-2022 08:38 AM
09-24-2022 03:23 PM
The first reply to this thread several hours ago said the same thing.
09-24-2022 12:50 PM
On your other post, you indicated that your account is closed so your old number will be on hold for 90 days.
Don’t know if you can retrieve it back but best to ask a CS_Agent.
You can only port a number over if your old account is Active. So the chances is very slim to porting your old number over.
You will need to purchase a new SIM, if your old account is closed.
09-24-2022 10:32 AM
You cannot change within. You can port out and close your account and then port back in. The question is where do your park your number? voip.ms or ??
09-24-2022 08:42 AM - edited 09-24-2022 08:44 AM
@youxing Hi if you port a number that account will close permanently but you can port that number to a new account with a new email and sim
