Transferring my number
glbm1
I received the notice to confirm the transfer from my old carrier and authorized it but my phone number still has not been transferred. I can make calls from my phone but I cannot receive them. Instead it goes to the voicemail of my old carrier. It’s been 2 weeks.
@glbm1
Sounds like your porting was not completed. Looks like you reply with YES to confirm that you are porting over to PM.
You will need to restart your porting process by private messaging a CS_Agent by clicking on the envelope icon on top of this page.
HALIMACS
@glbm1
To re-initiate the port, click here: https://urlshortner.tiia.ai/Lc9xk8
darlicious
@glbm1
Call the telus porting department number supplied by @softech with your old provider's account #. The info you supplied to port your number in likely contained an error especially if you used your IMEI as its easy to make an imputting error. Put your old sim card back in your phone to authorize the port request again. Then your port should complete within a few minutes to a maximum of 2 hours.
Welcome to public mobile!
@glbm1 2 weeks is toooo long. must be something wrong.
there is a number you can call to talk to live person  for update.   I will private message you.   Check the Community inbox,  envelope icon in the top right.
@glbm1  - 2 weeks, oh my. Is this a voip number you transferred over?
Cell numbers take 2-3 hours to complete.
Landline or voip numbers longer...but 2 week is long.
Try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
If still issues after above steps contact Customer Support (CSA)
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
