Transferring my Voip line to public mobile
Vijai1232
I have made a new activation and I want to transfer my VOIP line ###-###-#### but when I request, it says "This number isn't available". Can someone check if my port request has already been made or not when I called the VOIP line, they said they did not receive any VOIP request
RavingRaven
@Vijai1232
Which voip provider are you trying to transfer your phone # from? Did you follow their port out method? Some voip providers can take a week or more to complete the porting process.
@softech wrote:
@Vijai1232 you have not activated yet?? you got stuck at the porting step with the error??
check it you number can be ported into Pm first:
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
I tried that @softech while the number was still displaying and it said there was already an attempt made on this number.   So that tool is seemingly inconclusive, unless it already gave the OP some prior information.
