10-11-2023 02:58 PM
Authorized number transfer to Public from Freedom.... received message from Public that my account number not correct...how do I fix this?
10-11-2023 03:46 PM
Make certain you do not cancel or close your freedom account until the port to Public Mobile is fully complete and all services work.
If you do, the number may be lost and untransferrable here.
10-11-2023 03:36 PM
Confirm your Freedom account number and submit a ticket to CSA @Robo to complete the port.
Methods to contact Public Mobile Customer Support (CSA) below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], also found in various places in Public webpages, and bottom right corner of the page (See the Chat Bubble),
2-OR, go to your ENVELOPE at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message. Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support.
10-11-2023 03:15 PM
Hi, Login and try this link
10-11-2023 03:03 PM
There is a number to call to talk to live support and you can provide them the correct info, please provide account number of your old carrier. They can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
10-11-2023 03:01 PM
Not getting service with number transfer
