09-22-2018 07:31 PM - edited 01-05-2022 01:53 AM
Hi,
Transferred a number from PC mobile few minutes ago, I can make outgoing calls, but incoming call goes to voicemail directly. I can't receive and send text message. Please help, thanks a lot.
Ming
Joining Public
12-31-2018 02:42 PM - edited 12-31-2018 02:49 PM
Hi, I'm having the same problem, just joined public mobile and incoming calls are going directly into voicemail and I'm not able to text message from one particular friend using android. I'm on iPhone 7.
Could you please share your solution so I can give it a try, thank you.
Also, I tried putting @CS_Agent through private message in the 'Send to' box, and it did not match anything. Do I need a user name in front of of it?
09-23-2018 11:18 AM
@andyguan wrote:I am new here, how can I send a private message to moderator for help? Thanks.
@andyguan: Good to hear things are fine now.
@For your future reference, in the upper right corner of your screen you'll see a little envelope icon. Clicking on that takes you to the private messaging area. It's kinda like a mini email/webmail deal. Then you use the @ sign username to send to someone. For the moderators it's "@moderator_team" (not in quotes).
09-23-2018 10:59 AM
Everything works fine now, thanks a lot for all your help.
09-23-2018 08:42 AM
09-23-2018 08:40 AM - edited 09-23-2018 08:40 AM
@andyguan wrote:I restarted my phone and reset network settings. But doesn't work.
It is time to send a private message to moderator for help.
09-23-2018 08:26 AM
09-23-2018 08:23 AM
@andyguan wrote:I have the same problem after 12 hours waiting. What should I do now? Please help, thanks a lot.
If you can make outgoing calls, but incoming call goes to voicemail directly, restart your phone if you have not done so.
09-23-2018 06:46 AM
09-22-2018 09:18 PM
This happened to me too. Just have to wait and I also reset my phone and that worked too.
09-22-2018 07:43 PM
Thanks a lot.
09-22-2018 07:39 PM
Be patient. It looks like that your line is in the process of being ported over. It can take up to 1-2 hours for the port to be completed.
09-22-2018 07:38 PM
@andyguan wrote:Hi,
Ming
Wait for couple hours for the port to finish.
It happened to me last week. After the wait, incoming call works.
