03-03-2024 07:09 PM
I want to transfer my phone number from my old public mobile account to my new one. How do I do that?
03-03-2024 07:31 PM
Sounds good. Come back and let us know how it turned out. Just know due to their hours of work, they may not respond tonight but tomorrow since it's late Sunday night. 🙂 Good luck to you.
03-03-2024 07:29 PM
Okay, well thanks for the help, and I'll see what I can do by contacting them.
03-03-2024 07:28 PM - edited 03-03-2024 07:29 PM
Sadly no. But they've been known to upgrade. Just ask nicely. 🙂 I did. I was on the $29 plan and look what I got that was JUST for new customers. Use the link below I offered to contact a CS Agent.
I am a happy camper now!!
03-03-2024 07:26 PM
I currently have the $15 per month plan, but want to upgrade to the $24 month plan. Is that something I can upgrade to without contacting a CS Agent?
03-03-2024 07:23 PM
Once again, which plan are you on and which one do you want?
Before they allowed EVERYONE to upgrade to these new Canada US plans, I had to ask permission from a CS Agent. Now, no permission needed.
How to change plans
Log into your Public Mobile account, then click on Subscriptions and Add-ons.
Then go to Change Subscription.
Then choose the one you want. There will be 2 options. Change immediately or at the end of cycle. Change it for the end of the cycle. Meaning it will change next month and you won't lose anything you've already paid for this month.
03-03-2024 07:21 PM
Okay cool, thanks.
03-03-2024 07:20 PM - edited 03-03-2024 07:21 PM
Hey @Callum3
You can now choose any of the new promotions out there assuming you're talking about these ones.
https://www.publicmobile.ca/en/mb/plans?network=PROMOTION
You don't have to lose any of your Legacy Rewards or lose your number.
If you're talking about the $24 plan that's for new customers, if you are upgrading to to this plan, CS Agent have been known to upgrade. But if you're not upgrading, they won't do it. You can reach a CS Agent via the chatbox.
To submit a ticket, start with the chatbot at the bottom right corner.
Or the following link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Which promotion did you want?
Please note we are ALL customers here just like you.
03-03-2024 07:16 PM
Yes, I want to take advantage of their promotion that is only applicable to new accounts. That makes no sense that they can't transfer numbers between accounts, honestly this has me thinking of switching providers as their setup is insane.
03-03-2024 07:13 PM
@Callum3 Unfortunately, that is no possible. You will have to port out to another carrier then port back in since Public Mobile do not allow PM to PM number transfer as per their policy.
Is there a reason you would like to do this? You can take advantage of some new deals within your old account.
03-03-2024 07:12 PM
@Callum3 sorry, this cannot be done. PM no longer doing number swap between accounts. Many asked and got the same answer
