Transfer
artidubey1974
I missed to timely respond my Service provider message about transfer. How can I get question again, where I need to say "YES"
9 REPLIES 9
@artidubey1974
Didn’t you read the recommendations on your other post about Transfer?
You will need to contact a CS_Agent by creating a ticket through SIMon Chatbot at the bottom of this page or private message on the envelope icon above to restart the porting process.
Unfortunately, PM staff are available from 6:00am to 10:00pm but go ahead and submit your request.
Your old SIM is still active so continue to use it for now and wait for the text tomorrow.
@Quigley wrote:
@artidubey1974
Log into your account and ask for the port request again.
Or use the Chatbot Simon to get a service ticket started first and then ask for the port request again.  Your choice.
If porting has been attempted and failed, it can't be requested again in Self Serve. Only a CSA can do it.
@artidubey1974
Asking for a Port Request again here in the community forum, isn't the way to go or get it done.   Use the Chatbot Simon.
@artidubey1974 wrote:
Send port request again
Click on Chatbot (SIMon) link at the bottom of page.  You have to ask to open a CSA ticket.
artidubey1974
Quigley
@artidubey1974
Log in your My Account, and ask for the port request again.
Or you can ask for the port request again by using the Chat Bot Simon to get a service ticket started.
@artidubey1974
@artidubey1974   transfer into PM, right?
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get them to re-trigger the process
