Assistance with porting
MylesMorgan1228
We having issues porting our Public Mobile number over to Fido. The Kiosk person said the number was ported and threw out the SIM card. She gave us a temp number, but we wanted our old number ported over. Please help me figure this out, I have tried calling Public Mobile but can't seem to get a live person on the phone. What can I do to get my Public phone number ported over? is there an easy way to do this without so much hassle we even went to the Fido store with the phone, but we did not have any luck, and were told to go to a Public Mobile Kiosk but cannot find one in the Ottawa area. My wife is very angry that we lost her number Please help
As mentioend, Fido owes you $10 to replace the Public mobile SIM card.  If it's a postpaid Fido account that you have signed up for, I would at least consider backing out of it under the 15 day satisfaction guarantee.
The pickle here @hTideGnow is that the 'genius' Fido representative allegedly threw out the OP's PM SIM card.
Not a nice start at a new provider for them... unless THEY responded "YES" for the OP and the number port is actually in progress.
@MylesMorgan1228 , contact FIDO to see if that's the case.
Worst case, if you must contact Public Mobile, here's how:
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
HALIMACS
@MylesMorgan1228
In order to do this your Public Mobile account must be active and you need to keep your old PM SIM card in your device to respond "YES" to the port authorization request.
If you didn't do all of the above, you're out of luck.
And for the record, the issue is with the Fido person, NOT Public Mobile.
I really hope the Fido representative didn't throw your PM SIM card away.  If the DID, demand they cover the cost of a replacement (which may take awhile to get - try TELUS, Koodo, or Mobile Klinik locations), then sign into your PM self-serve account, perform a SIM card change on the self-serve screen, then request that Fido re-initiate the port, making sure the PM SIM card is in your device.
Hi @MylesMorgan1228 the kiosks person should have done everything for you.
Basically you just need to make sure your PM account is active.  Then ask Fido support to request porting, you provide them PM account number.
Then PM will send you text and you reply YES
pls go back and check with Fido support to restart that porting request
