08-07-2026 04:27 PM
I received the message type yes. I did so in the time allowed. Nothing happened. Later received message to type 1 because the didn't receive confirmation. Done Nothing happened.
08-07-2026 04:30 PM
There is a number to call to talk to live support, they can provide you an update with the porting request. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
