08-09-2024
12:53 PM
08-09-2024
04:09 PM
computergeek541
Can I transfer number from another provider to public mobile
08-09-2024 08:14 PM
I have successfully transferred two numbers from Bell Mobility to Public Mobile and it was a very simple and straightforward process.
08-09-2024 12:56 PM
yes, i did it when i came to PM.
You want to do a number port, you will be porting out of your old carrier and into PM, just remember you must keep your current service active until the transfer process is complete.
08-09-2024 12:56 PM - edited 08-09-2024 01:01 PM
you sure can as long as it's a Cdn number and not propitiatory proprietary to a particular network. Download the free PM app and you'll get option to transfer there...just don't cancel old acct until successfully ported in to PM.
ed sp
08-09-2024 12:55 PM
@Dainty1 In most cases yes but it’s best to first check that your number can be ported to public mobile
Check to see if # can be ported
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
