Transfer number
Thiagomv
I've asked to have my number transferred on Nov 17 from Virgin and so far my account still active with them. I have been told that Virgin did not receive the Yes confirmation for the number transfer and Public Mobile needs to send a new request. I tried to contact public mobile and so far anyone can help with. Very disappointed and thinking of my moving somewhere else where there is a live agent to fix problems.
@TomPham  Yes . Sent !
TomPham
Can you send me the porting team number? I have been asking many people but no reply.
@Casperr0426
The problem you is operator error my know what to do and not following the porting steps in order.
Casperr0426
This is a common problem if you read various threads here
@Thiagomv
You need the Virgin SIM in your phone and not the PM SIM to receive the text!
Just put the Virgin SIM and you will see the text. This is not a PM issue, it is a Virgin issue because they are the one that will send you the text.
You will need a CS_Agent to restart the porting process for you again.
@Thiagomv  I’ll send you the porting team number to your in box right away and they can re trigger the port request for you
