4 weeks ago
When I remove the Rogers SIMcard I can no longer make any calls or texts. As well as Rogers has not cancelled my account after 6 days.
4 weeks ago
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
4 weeks ago
Yes I did receive the text from Rogers, replied with "Yes". I will try calling the port assistance team. thanks
4 weeks ago
A stuck port from Rogers is very common, and it usually means the mandatory security handshake between the two carriers timed out or stalled.
When a port is stuck, you will often experience "split service"—where you can make outgoing calls and data works on your new Public Mobile SIM, but all incoming calls and texts are still routing to your old Rogers SIM.
Here is the exact step-by-step checklist to get this fixed.
To prevent unauthorized slamming (phone fraud), Canadian carriers require you to explicitly approve a number transfer via text message. Put your Rogers SIM card back into your phone. Look for an automated text message from Rogers that asks you to confirm the transfer. You must reply "YES" to this text within 90 minutes of it being sent. Did you miss the text or leave it too long? If the 90-minute window closed, the port request automatically locks up and expires. Proceed to Step 2 to have it manually retriggered.
While Public Mobile doesn't have regular phone support, Telus operates a dedicated backend Porting Support Team that handles stuck transfers for Koodo and Public Mobile. Calling them allows you to bypass the web tickets completely. The number, for some odd reason, is not permitted to be placed on these forums. However, members here, like myself, can send it to you in a private message. Check your mailbox here.
4 weeks ago
sounds like the number transfer has failed. You can message Customer Support using this link to ask to have it started again...
4 weeks ago
If Rogers account is not closed, then the port was not done. Did you reply the text from Rogers to approve the port?
There is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link:
And CS_Agent will reply to your community inbox, check here:
