Transfer from Rogers. No incoming call
itimjob
hi there
I just transferred my Rogers number to PM yesterday. But can't get incoming calls.
I can make phone call and receive text msg. LTE works. When I call my number, it goes to my Rogers's Voicemail box.
Private msg to mod.but no reply. 😞
8 REPLIES 8
itimjob
It works now thx 😉 @Mary_M
itimjob
@Mary_M thx but wondering if you need my SIM no. Or even my phone no. ??
Mary_M
Retraité / Retired
Retraité / Retired
Good morning @itimjob
Thank you for your patience, it's greatly appreciated.
In regards to your port, I was able to resubmit it with the account number provider. It should be completed within 2 hours, and you'll get a confirmation text. Simply power cycle your phone and enjoy 🙂
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
@jackfzhao True, however until the transfer finishes he must pay for both services. Only phone numbers from active accounts may be transferred. Robot Sad
jackfzhao
@Luddite wrote:
Expect a delay of several days.
So suggest:
a) use your Rogers SIM; if it still sends & receives calls just use it until it stops, or
b) use two phones, or
c) get app from fongo.com, then forward Rogers to it; answer incoming on fongo & call on Public Mobile.
Please let us know if option a) actually works. I have forgotten.
but another issue created: he got to pay for 2 services, rogers n pm
So suggest:
CaNuCk07
hey @itimjob  looks like your port is stuck.  You've done the right thing by private messaging the moderators.  Just have to sit tight, volume is super high right now, they'll get to your issues as soon as possible.
JaK
Hi @itimjob, welcome to Public Mobile.
Sorry to hear that the port appears to be stuck, pretty likely needs a moderator and as I suspect you've already seen they are backlogged right now due to this promo. Since you already messaged them, not much to do but be patient. Good luck.
