06-17-2020 01:15 PM - edited 01-05-2022 11:44 AM
I’ve recently activated my SIM card and called to cancel my current plan (With the other provider) but they said I need to have my number transferred over to Public (which I thought was done in store). How do I get my # transferred to close my current account successfully?
06-17-2020 08:30 PM - last edited on 06-17-2020 11:10 PM by computergeek541
When you activated in the store to transfer your number, they should have confirmed your phone number to you at the time. If your account with your previous provider is closed then you cannot take your number anymore. you can try to reactivate with your previous provider just so you can try to transfer your number once more.
I hope all works out well for you.
edited by computergeek541: referrral code removed
06-17-2020 01:42 PM - edited 06-17-2020 01:56 PM
If you have already activated your sim card and chosen a temporary number you will have to have a moderator port your number for you. Follow the instructions given by @Jb456 as to how to contact the moderators.
If Simon gives you the run around.....you can also send a private message thru your private messages by tagging the @CS_Agent in the address bar. Put "port number" in the subject line and include the following info:
Keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a message from the moderators. Responding promptly to messages will speed up service times.
06-17-2020 01:34 PM - edited 06-17-2020 02:18 PM
also make sure your current device is unlocked, you can ask for the unlock code from your previous provider. if it's Telus or koodo there is no need
06-17-2020 01:33 PM
@jacquelinedara the port will close your account for you. It needs to be active to port. Stay safe.
06-17-2020 01:23 PM
Yes you have to keep old provider account active to successfully port your number. The system will notify old provider that you ported and the account will be closed automatically.
Don't forget a referral code for a $10 signup bonus.
Here's how to port.
There have been issues with porting. Here is what PM is recommending.
