05-09-2022 01:35 PM
So, like 5+ years ago, I had a PM account. Stopped paying, let it deactivate.
1 month ago, got a new PM SIM, but used the same email address that was associated with the previously deactivated account - was not aware that I would not be able to access self-serve through a deactivated email.
So, this month, got another PM SIM with a new email address so that I can access self-serve. But I like the number associated with the previous SIM from last month better and would like to transfer that if that's possible.
When I go to Plans & Addons there's only the option to transfer "from another provider", and when I check to see if the previous number is eligible, it says "unable".
Is there some other way to go about this? Thanks.
05-09-2022 07:17 PM
Did they tell you that an old PM email won't work??
I was with PM for a couple years about 4 years ago, left...just came back a few months ago and obv had a deactivated account (with wonderful old rewards I might add) but was able to sign up for my self serve with the same email I used initially.
05-09-2022 02:14 PM
@hTideGnow suggestion is the simplest way to go, ask customer support to change emails on the account with the number you prefer.
05-09-2022 02:13 PM
@ArmFreq wrote:How would I go about contacting an agent?
To contact CSA, there are 2 methods:
- Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click Chatbot - Ticket and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented. If ticketing does not work very fist time do the below.
- Send a private message to the CSA - agent by clicking Here
In either case watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar.
05-09-2022 02:12 PM - edited 05-09-2022 02:13 PM
Yes, your summary at the end is correct. The problem is that the email associated with PM Account#1 is from a previously deactivated account which means I can't access any of the self-serve options. How would I go about contacting an agent?
Edit: nevermind, the other fellow told me how. Thanks.
05-09-2022 02:12 PM
HI @ArmFreq yes, get another email. Then open ticket with PM CS Agent and they can change the email from that deactivated email to your new one. To contact CS agent, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-09-2022 02:10 PM
I don't keep using the one from last month because it's associated with the deactivated email which means I can't access self-serve. Is there someone I can contact to change the email associated with the deactivated account without going through the self-serve options? How would I go about that? Thanks.
05-09-2022 01:42 PM
HI @ArmFreq , if you like the other number more, the one from last month, why don't you keep using that one? I know you have a email address associated with that one and you don't like that, you can in fact ask PM to change the email address for that account for you (the only from last month). but you have to pay for that account again to reactivate
For the one you don't like it (the one from this one), you can let it expire, do not pay again at the end of this month
I think this arrangement is easier
05-09-2022 01:40 PM
You cannot transfer number from one PM to another PM account.
There is a possibility to do that with agent's assistance but general question is No.
So you are saying you opened PM Account#1, got nice number, then opened PM Account#2 and want to transfer number from #1 to #2?
