11-13-2024 09:58 AM - last edited on 11-17-2024 12:55 PM by Dunkman
Hello, I am transferring number from Freedom to Public Mobile. I tried transferring yesterday and it says on my phone Public Mobile. But, I can only make calls. Any texts and calls made to me, are not going through. Also, the text messages I try to send do not go through.
I called Freedom and they said they ported the number out. They told me to contact Public Mobile to finish process.
11-13-2024 10:12 AM
@Shoffi2024 Support usually reply in 1-2 hours sometimes longer but
11-13-2024 10:06 AM
Yes, I replied Yes to the text received from Freedom. But, I haven't received any texts from Public Mobile
11-13-2024 10:02 AM
You did reply YES to the text received in order to complete the porting?
11-13-2024 10:02 AM
I tried rebooting multiple times, but not working. Will contact CSA, Thanks!
11-13-2024 09:59 AM - edited 11-13-2024 10:00 AM
@Shoffi2024 first try and reboot the phone . If no luck no worries just
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
