10-15-2019 07:01 PM - edited 01-05-2022 07:35 AM
10-16-2019 03:22 PM
@ekkian1 wrote:this plan is now expired, HOWEVER, you can get 10GB + 2GB of bonus data = 12GB for $60
This plan isn't comparable for somone wishes to have a plan that includes U.S. roaming. This plan only works in Canada (unless a separate U.S. roaming package is purchased).
10-16-2019 11:34 AM
this plan is now expired, HOWEVER, you can get 10GB + 2GB of bonus data = 12GB for $60, this plan runs until October 28, 2019. for the bonus 2 gigs, use promo code "PMOCTOBER12GB"
10-15-2019 11:22 PM
@ccubedYou will still get the plan.. However if you do change your plan anytime in the future, you will loose the option to change back to the plan if you change your mind.
10-15-2019 11:19 PM
@ccubed wrote:Does anyone know what happens if you signed up for this plan BEFORE October 6th with a start date set as the next monthly renewal (in my case Oct 24)? Will PM honour the plan upgrade that I signed up for prior to the plan being discontinued even though my start date is after it was discontinued?
Thanks..
Yes you'll still get the plan.
10-15-2019 11:18 PM
Thanks..
10-15-2019 09:21 PM
Going going gone
10-15-2019 08:19 PM - edited 10-15-2019 08:20 PM
@sexylady1979 wrote:
You had to get it on October 6 or before. Add-ons are the only roaming option now.
10-15-2019 07:03 PM
@sexylady1979 Yes it was expired recently. It was a time limted promotion. Sorry.
