Ticket
paisaottawa
I can get incoming calls, but I can’t make outgoing calls. Thanks for your help with this.
paisaottawa
I did it and still does not work for me.
hi @paisaottawa do you have $15 plan and no more outbound calls minutes? Check My Account
if you have minutes left or plan above $15, try reboot your phone and try to call with a 1 in front of the 10 digits
Meow
Did you recently transferred your number to PM?
For ticket go to chatbot and type 'ticket'. Follow prompts... If ticketing does not work chatbot will let you know how to send a note to agent.
