03-30-2022 07:17 PM
03-30-2022 08:25 PM
03-30-2022 07:46 PM
Try one or more of the below:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*can you try your SIM into another compatible phone to see if texting works then?
If you have an iphone and you turn your data off occasionally, then it is recommended to turn off iMessage altogether and use regular text messaging instead.
To do this, go to Settings > Messages and toggle iMessage off.
If you prefer to use iMessage, then you can perform the following steps to fix the issue:
03-30-2022 07:26 PM - edited 03-30-2022 07:26 PM
If you have an iPhone, go to Settings>Messages>enable Send as SMS and enable MMS Messaging.
Also check if your Cellular Data is enabled.
