Texts troubles
Gogeen36
Not receiving texts or phone calls. Tried everything to fix it but no go
7 REPLIES 7
@Gogeen36   If you don't want to reset all settings try turning airplane mode on, wait a minute and then turn it off again and see if that works.  If not you can contact customer service by sending a private message using the link @Handy1 gave you earlier.
Gogeen36
Long time customer
@Gogeen36
You might want to clean the copper contacts with a microfibre cloth before putting it back into the phone and powering back on.
Yrs you need to re-enter the wifi password and the cellular settings.
Phil_Adelphus
@Gogeen36   Did you just transfer from another provider or are you a long-time Public Mobile customer?
@Gogeen36  Just wifi password yes and re connect any blue tooth accessories
Gogeen36
Yes rebooted also removed SIM card and put it back in. If I reset network settings will I lose passwords
@Gogeen36  Have you rebooted the phone ? Or tried to reset network settings ? Also check
Outage map in your area:
https://istheservicedowncanada.com/
if still no luck submit ticket with support to investigate for you
send  a  private message   To CS_Agents
