Text
04-27-2022 02:20 PM
04-27-2022 03:26 PM
We will be able to lead you in the right direction with a few more details
04-27-2022 03:11 PM
Known outage at Telus
https://productioncommunity.publicmobile.ca/t5/Get-Support/FYI-Text-Outage/td-p/817074
04-27-2022 02:32 PM
HI @Michaelap A lot more info needed
iPhone? Android?
calls and data working?
which area you are at?
You tried reboot the phone?
did you try to put your SIM in another phone?
did you just join and have problem? or it was working with your PM SIM before?
04-27-2022 02:22 PM
More info please...have you recently ported from a previous cell provider ?
04-27-2022 02:22 PM
Try rebooting phone, resetting network settings, reinstalling SIM card.
Also clear the cache on the messaging app.
