Text
jeepman1256
Hello,
All texts from my friend are not being delivered. She does receive mine to her. Any suggestions?
Thank you,
Guy
@jeepman1256
Very likely you have turned your chat features on....are your chat bubbles dark blue when they used to be light blue? Turn them off in your settings.
This question has been coming up a lot lately. Ever since the google update I think the pop up prompting you to enable feature is front and centre. However its designed even though I did not want it and I thought I was dismissing it I instead enabled it. I didn't notice right away until I called a couple people eho didn't answer a text and Input it together. But I have now done it two more times on other phones that I was helping troubleshoot! Very sneaky....pop up design!
both of you can do this,
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
How to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  HERE
click HERE
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
for iphone  go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your DATA is on.
Good Luck
@jeepman1256  did you just join today?  did you request a number porting?   If so, can you receive incoming calls?     If you just joined and request porting, it might be an indication of a stuck port.
If you have joined PM for some time and have been receiving incoming calls, then did you just change phones?    Also check if your Airplane mode is OFF and check if it is an issue with iMessage or RCS chat issue as mentioned by @Dunkman
Give us more information like what kind of phone you have and what have you done so far.
Dunkman
@jeepman1256
Were you able to receive texts before from your friend?  Any recent changes phones with either one of you?  Any issues with other friends or family texts? Issues with calling or data?
If one of you are apple users, it can be an issue with iMessage.  Turn on data for iMessage.
If Android users, turn off android chat feature.
Other basic trouble shooting advice:
Reboot phone
Network reset of phone
