04-17-2020 12:04 PM - edited 01-05-2022 11:41 AM
I text an image of a void cheque to an incorrect number. When I call the number, it always says, "we're sorry, this number cannot be completed as dialed." I have access to long distance, and tried adding a 1 in front of the number (as well as not). It has a 637 area code (I'm not even sure that works for North America). My feeling (and hope) is there's no one at the other end of this number.
However, since we have global text, and the text did not bounce back saying "undeliverable," I'm concerned that I may have successfully text someone, somewhere in the world. Have I? Is there any way to check? Can I check if the number is valid? Can I check with Public if the text went through and was delivered? Really would like to avoid the hassle of changing my banking info.
Service
04-17-2020 02:20 PM
@oglat ...well said.
Many years ago i got a few texts and they were for a different person, it happens. I even had a voice message.. the things is My name is said before you leave a message, so the person should have realized it was not the person he wanted to leave a message to.
04-17-2020 02:03 PM
Thanks Oglat - this sounds accurate and gives me piece of mind (whether accurate or not), so I said this was the solution. Based on the other posts I'm confident it's not going to be delivered in North America. I was just worried someone has that number in some other country, and with just an area code and 7 digit number it could potentially be delivered to another country.
04-17-2020 02:00 PM
I would like to make a small suggestion for any kind of communication be it private messaging, sms, email... If you are sending something sensitive like that, first establish contact by test message, once you get positive response you can do it by replying. Also watch out for group messages, I've seen messages sent to the whole group and was really intended for only one member of the group, I believe it happened while selecting recipient from there drop-down (probably the last communication was offered first)
Hope that makes sense
04-17-2020 01:46 PM
I would like to commend you, i really appreciate, when you include a picture, it really, helps. For us visual people. Well done.
04-17-2020 01:41 PM
If it does say Ontario then you have absolutely nothing to worry about. The messages wait to be downloaded for 5 days then they are lost forever. That area code is not in use so nobody can open an account with that number to receive it in 5 days.
Just resend your sms to the right number
04-17-2020 01:28 PM
Ya, I mean, it looks like it went through (in that it looks the same as other MMS transactions), although usually the "destination location" says ON, but in this case it's blank.
04-17-2020 12:45 PM
It never bounces back
If you put 1 on front it went nowhere to if you didn't most likely it went nowhere too but if you are uneasy you could get long distance card and try calling it with 011
You could change your account easily by calling your bank, for me it was done in minutes. but it may cost you getting new cheques and deal with all direct deposits and autopayments
04-17-2020 12:33 PM
@dennchipp wrote:I text an image of a void cheque to an incorrect number. When I call the number, it always says, "we're sorry, this number cannot be completed as dialed." I have access to long distance, and tried adding a 1 in front of the number (as well as not). It has a 637 area code (I'm not even sure that works for North America). My feeling (and hope) is there's no one at the other end of this number.
Once a text is sent it can't be recalled...but the area code you sent it to hasn't been assigned. Keep an eye on your bank account activity for a few weeks just to be sure.
04-17-2020 12:30 PM
@dennchipp , you are in luck, area code 637 has not been put into use. The text probably went nowhere. Just as a suggestion, it is rather dangerous to freehand a recipient for something as important as a cheque. I would be comfortable if it was uploaded through an official app.
04-17-2020 12:22 PM - edited 04-17-2020 12:24 PM
To contact a moderator for their input use this link:
04-17-2020 12:16 PM - edited 04-17-2020 12:17 PM
Also, go into self service in usage history to see if the text was sent.
04-17-2020 12:09 PM
@dennchipp I get this when I search the code Area Code 637 has not been assigned for use by the North American Numbering Plan Administrator. Area Code 637 is officially planned as a General Purpose area code which is typically assigned to a geographic area. If you receive a phone call from area code 637 it is a spam call.
https://www.areacodehelp.com/where/area_code_637.shtml
So you may be in luck. But to be on the safe side change your banking information. Stay safe.
04-17-2020 12:08 PM - edited 04-17-2020 01:42 PM
Have a look at this regarding 637...I am not really sure if it is a valid code or not?
